m20b23 injectors doesn`t work while starting
  • dableds
    • Mar 2005
    • 53
    hello
    i have a liitle problem. here`s my story.
    i`ve bought e30 325eta `85 and swap into it, m20b23.
    set up all wires, contacts.
    computer number 301 and air - 031
    sparks is ok, working...
    But when i start starter - injectors doesn`t spray fuel in cylinders.
    i`ll checked with tester, and when i`m starting - starter - there`s no voltage in injectors connectors.
    fuel pump is working...
    where can i search some hint?
    which "section" is opening (starting) injectors?
    soorry, my bad english, hope you understand what i need to know :)
  • nzer
    • 122
    Did you convert the m20 b23 to motronic? Or leave it L-Jet?
    • dableds
      • Mar 2005
      • 53
      L-Jectronic
      • gstuning
        • 833
        Does it behave the same with afm unplugged??
        Gunni
        @ Prodrive / Aston Martin Racing
        • dableds
          • Mar 2005
          • 53
          now everything`s fine
          i just changed engine wiring, and engine starts :)
          admins can close or delete this topick.
